Issue to uplad document for signing
  • October 20, 2025
  • 3 replies
  • 102 views
Dear all,
I am experiencing an issue when trying to upload a document. I’m the account owner and have invited my colleague to join. However, when I press Upload, the browser keeps spinning indefinitely and never completes the action.
Interestingly, my colleague doesn’t have this issue and can upload documents without any problem.
Has anyone experienced something similar? Any suggestions would be greatly appreciated — it’s quite frustrating, and I’ would really prefer not to close the account.
Many thanks,
Sanja
  • Newcomer
  • October 20, 2025
We are having issues when signing in the demo environment. I believe DocuSign uses the Amazon Web Services that experienced an outage and it is affecting the load times today. We reported it to their support team.
Forum|alt.badge.img+14
  • Community Moderator
  • October 28, 2025
Hello ​@Sanja ​@LaurenDS
Thank you for reaching out to us. We’re happy to help! When experiencing issues in Docusign, the following initial troubleshooting steps often resolve the most common scenarios:
1. Verify Account & Access.
  • Ensure you log into the correct environment (Production vs Demo). Confirm your user account is active and has the necessary permissions.
2. Browser and Device Check
  • Clear browser cache and cookies. Try using a different supported browser (Chrome, Edge, or Firefox). Disable browser extensions or test in Private/Incognito mode. Ensure cookies and JavaScript are enabled.
3. Email Delivery Validation.
  • Check spam or junk folders. Confirm the email address used is correct. If needed, have the sender resend the envelope.
4. Document and Envelope Review.
  • Check routing order and signer assignments. Make sure files are supported, not password-protected, and within size limits.
5. Authentication and Login Support:
  • If using Single Sign-On (SSO), confirm access with your IT team. If applicable, reset the password and ensure the correct regional login URL.
If the issue continues after completing these steps, please provide any error messages, envelope IDs, or screenshots so we can investigate further. We are committed to getting this resolved quickly.
You can also check if there is an outage on going here.
  • November 4, 2025
