Matthew.Farler
Jun 2, 2025 7:16 PM UTC
Party Management Basics for Docusign CLM
  • Jan 30, 2026 1:19 AM UTC
  • 2 replies
  • 268 views
  • Translate All
Description:
Are you looking for a way to better organize your agreements in Docusign CLM? Want to quickly be able to calculate your total contractual commitment to different customers and vendors, using the Party Management capability in Docusign CLM? Check out this Trainer Tip video by Docusign University’s Matt Farler for a quick explanation of what Party Management is all about, and how to get started by adding parties to your account, both individually and in bulk.
Key Takeaways:
  • Agreements across your account can be organized by Party, leading to several organizational benefits
  • Admins can create parties on an account, either individually or in bulk
  • Adding parties automatically creates a folder for them in the account’s Parties folder
  • Users can directly associate agreements with existing parties
Additional Resources:
neethujkp
Frequent Contributor
Oct 2, 2025 10:28 AM UTC
Can we create custom fields under Party? Like Vendor Contact, Vendor Email, Vendor Address etc?
If you believe my answer effectively solves your problem, please remember to mark it as the best answer and consider following me.
Matthew.Farler
Oct 2, 2025 3:32 PM UTC
Not specifically for Parties, but you can create Custom Attribute Groups at any time and tag those to your Party documents, as well, and they function largely the same.  Here’s a walkthrough for how to do it.
Matt Farler, Principal Product Trainer, DSU
