Oct 14, 2024 6:10 PM UTC
Docusign Trainer Tips: Send for Signature using Docusign CLM
  • Dec 11, 2025 9:00 PM UTC
  • 0 replies
  • 114 views
  • Translate All
Ready to get your agreements in Docusign CLM signed by the necessary recipients? Using Docusign CLM, you can send a document out for electronic signature. Documents can be sent for signature manually or automatically via a CLM workflow.
In this video, a Docusign Product Trainer will walk through the process of sending a document from CLM out for signature. You’ll observe each of the steps, adding recipients, customizing messaging, and dragging/dropping fields onto the document. You’ll also observe the signing experience from the recipient’s perspective and how the document returns in Docusign CLM once signed.
Additional Resources:
Continue the Conversation
Will you be sending your CLM documents out for signature? If so, do you plan on using the manual method or will you be sending through a workflow?
