OAUTH Error when users try to authorize their Docusign account in Salesforce to send their 1st envelope
  • September 9, 2025
  • 18 replies
  • 6089 views
The error message says “OAUTH_APPROVAL_ERROR_GENERIC : An unexpected error has occured during authentication. Please try again.”
Best answer by Ian-Pro
Docusign updated their security settings yesterday. We fixed our issues by doing the following (you have to be an admin for Docusign in Salesforce):
  1. In Salesforce, click the cog and navigate to Settings.
  2. In search, type “OAuth” and select “Connected Apps OAuth Usage
  3. Find Docusign and select the “Manage App Policies” hyperlink
  4. Select “Edit Policies”
  5. Under OAuth Policies > Permitted Users and set it to “Admin approved users are pre-authorized”
  6. Click Save
  7. Scroll down and select “Manage Profiles” in the profiles section and allow the profiles for your senders
  8. Click “Save”
  9. Have one of your users (non-Salesforce Docusign admins) test if they can send docs again
I hope this helps everyone experiencing the issues!
We’re seeing this issue as well. Started yesterday and not sure how to resolve. Following
Conversation Starter
September 9, 2025
Same issue. Following
We are also having this issue. Following.
Ian-ProConversation StarterAnswer
September 9, 2025
  6. Click Save
  8. Click “Save”
Active Voice
September 10, 2025
Same issue in our environment as well. Any updates on this? We have raised a case and waiting for an update.
Active Voice
September 10, 2025
  6. Click Save
  8. Click “Save”
I dont see the option for “Manage App Policies” under Docusign in the Connected Apps OAuth Usage section.
September 10, 2025
It is in the middle of the row. If you can’t see it, you may need to check with the Admin that installed the package or delete it and reinstall if they no longer work there.
  6. Click Save
  8. Click “Save”
  6. Click Save
  8. Click “Save”
This fix worked for me!! Thank you so much ​@Ian-Pro. ​@vmuthu I had to click ‘Install’ to get the ‘Manage App Policies’ option for whatever reason. After clicking install, I was able to follow Ian-Pro’s steps.
Thank you for the responses.
My users are having similar issue. I do not see Install or Manage policies when I go to ‘
Connected Apps OAuth Usage’
Any suggestions please!!
