Creating Envelopes with NextJs
  • January 20, 2025
  • 2 replies
  • 36 views
Forum|alt.badge.img+2
I’m using the DocuSign Node.js package to create an envelope in my Next.js application. I have imported the necessary classes from DocuSign as:
import { ApiClient, EnvelopesApi, EnvelopeDefinition, TemplateRole } from 'docusign-esign';
But, it seems like I am unable to use the “EnvelopeDefinition” method. I have it as:
// Prepare the envelope details
const envelopeDefinition = new EnvelopeDefinition();
The issue I’m having is that I get the message; “'EnvelopeDefinition' only refers to a type, but is being used as a value here.” when try to initialize the envelope definition.
What am I doing wrong? Can someone please asssist?
Forum|alt.badge.img+7
  • Docusign Employee
  • 59 replies
  • January 21, 2025
Hello Team
The issue is likely due to how TypeScript handles type-only imports versus actual value imports.
const envelopeDefinition = { / initialize your envelope details here as an object / }; Or,  may be as below:
  emailSubject: "Please sign this document",
  templateId: "your-template-id",
  templateRoles: [
      email: "recipient@example.com",
      roleName: "RoleName",
  status: "sent",
This approach works as EnvelopeDefinition in DocuSign SDK might not be a JavaScript constructor. Instead, the SDK uses plain objects for configuration.
Please try and if you still see issues then please log a case with DS Support attaching logs  https://support.docusign.com/guides/ndse-user-guide-api-request-logging & we will investigate from there.
Thankyou
Sai
  • Author
  • Newcomer
  • 1 reply
  • January 22, 2025
Hello Sai
Thank you for your response to me enquiry. I’ve managed to work around the issue by using the RESTAPI instead. I found that I was encountering numerous issues when I used the DocuSign SDK. I’ve implemented a similar structure as you’ve proposed in your solution and my application is now working as expected.
Thanks your for your assistance.
Kind regards,
Yattish
