Using DocuSign with Stripe
I have a SaaS product which already uses Stripe, I want to offer users the option to pay by invoice, so I added DocuSign to Stripe and I’ve created a template, but I can’t work out how to set up the workflow where a user clicks on a “pay by invoice” button is given the DocuSign order form. Ideally, I’d like to use a web form, but there’s no obvious pathway for managing these features and the documentation seems to be all about hitting the SEO algorithms rather than helping users. Do I have to use the DocuSign API for this process?
June 29, 2024
@woodbine
To integrate Stripe payment processing with DocuSign, follow these steps:
  1. Add Your Stripe Payment Gateway: If not already done, integrate your Stripe payment gateway with DocuSign. This allows you to collect payments directly through your documents.
    Learn how to Add a Payment Gateway (docusign.com)
  2. Configure Payment Tab: Once integrated, configure the Payment Tab within your document templates. This tab enables you to set up payment fields where recipients can make payments while signing.
  3. Additional Resources: For detailed guidance, refer to the Requesting One-Time Payments Along with Signatures (docusign.com) video tutorial. This resource provides comprehensive instructions on setting up and using payment features in DocuSign.
If you generate invoices from your own application and pass data into DocuSign templates, you can specify invoice amounts in the Payment Tab. This allows you to request payments from recipients before they can finalize the document envelope.
June 29, 2024
@woodbine
Hi @woodbine,
