power automate "Get recipient tabs from envelope" radiogroup missing tabLabel and tabId
I am using Power Automate to retrieve fields from a completed document; however, all the “radio group" fields are missing “tabLabel” and “tabId” information. Please advise.
Ma.CubioAnswer
Hello ​@Aleksandr-8543,
Those elements are missing since you are using docusign trigger then you should use the output of "tabs" in the workflow instead.
