Digital Collaborator
October 2, 2024
Under review
Request to add a sender notification which will notify senders when an envelope is due to expire
Categories:eSignature
It would be very helpful if the envelope sender was notified before the envelope expired. Envelopes often expire as the sender has been unaware that they were reaching the expiration date.
Hengfeng Ge
Hero
Hero
October 3, 2024
maybe right now you can change the default expirartion days from 120 to 999. we write python code for bulk update the envelopes of expiratition days for our customer recently. there are more then 500 envelopes will expirate in one week.
FreeLink/甫连信息
🏆 2024 APAC Reseller Growth Partner of the Year
🔧 The first in APAC to pass the DocuSign eSignature Technical Consultant certification.
🚀 Expertise in DocuSign integrations with on-premises systems for leading enterprises across various industries.
Feel free to reach out for collaboration opportunities.
This is a very needed addition - we regularly have one person that doesn’t sign an envelope and then the entire packet is voided without notice.  The reminder would give the sender a chance to save a copy or revise the envelope before it is voided.  Please make this change!
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
Active Voice
May 16, 2025
Hi ​@Jenny.Martin
When are we likely to see this idea developed?
Many thanks.
Kenneth
Digital Leader
May 16, 2025
Hi ​@Jenny.Martin
Many thanks.
Kenneth
Good question - what is the timeframe from “idea” to implementation?
mr1
MR1
Hello ​@Kenneth, ​@mr1,
Thank you for reaching out.
Unfortunately, we do not have an exact timeframe for when an idea will be implemented. The development process is dynamic, and priorities can shift from needs and feedback from users like you.
Each idea is assigned a status to show its progress:
  • Idea Submitted: The default status for all ideas. When ideas are at this status, you are encouraged to upvote an idea or comment on it with your inputs to help the idea move into review.
  • Under Review: The idea is being evaluated by Docusign.
  • Planned: The idea has been selected for teams to begin developing.
  • In beta: The idea is available for early access and testing
  • Parked: The idea is viable, but is not currently considered at this time.
  • Delivered: The idea is implemented and live.
  • Existing functionality: The idea can be solved within the set of capabilities and platform services that exist today.
  • Duplicate: The idea was a duplication and merged with existing Idea.
Please also note that we cannot guarantee that every idea will be implemented or implemented exactly as suggested.
Active Voice
May 19, 2025
Thanks for your response Jenny.
What is the average lead time or criteria before the status of the idea will change to Under Review.
