Need Sender to fill out required fields and signer to fill out fields based on senders required fields.
  • April 15, 2026
  • 0 replies
  • 7 views
Forum|alt.badge.img
For example, if there is a form that has 10 hard coded sections for wire transfers.
1. The sender would be required to fill out first 4 fields for as many wire transfer sections they will need from the recipient with a minimum of being at least first section up to 10.
2.  The recipient would be required to fill out the last 3 fields in the sections that have data that was filled out by sender
3.   If a section has no content from the sender, then the recipient does not have to fill out the last 3 fields in that section.
Is there a way to ensure client fills out last 3 fields for each section the sender has data in the first 4 fields?
