How to capture radio button value from Power Automate
  • April 22, 2025
  • 2 replies
  • 167 views
Forum|alt.badge.img+1
My document has a radio button with four choices.  The signer clicks one of the radio buttons and signs the letter.  That works fine.  I then run Power Automate to save the signed letter in a Shaerpoint folder.  That works fine.  I have another Power Automate flow that reads information from the envelope and creates a record in a Sharepoint list.  This works fine as well.
The only thing I can’t do is read values from the fields in the signed document.  I need to add the radio button value to the Sharepoint list together with the other envelope data.  Any ideas?
Hello ​@Azautomation,
I understand you can’t read values from the fields in the signed document, and need to add the radio button value to the Sharepoint list and the other envelope data. I sincerely apologize for this, and rest assured that I'll make my best effort to provide you with a solution that works.
To confirm, are you using the Docusign trigger? If yes you can use the output of "tabs" in the workflow:
I hope this is helpful. If you consider the response above useful, please click “Select as Best” to mark it as the “Best Answer ✅.” This will assist other users with similar questions in finding it more easily. Let me know if you need further assistance. Thank you!
Forum|alt.badge.img+15
  • Community Moderator
  • Answer
  • April 24, 2025
I trust all is well. If you found my response to be a useful solution to your question, could you please click the "Best Answer ✅" button at the bottom of the post? It helps other community members who might have similar questions. Please let us know if you need further assistance. Thank you!
