Group Tabs Minimum Required Checkbox
  • April 25, 2025
  • 4 replies
  • 120 views
Forum|alt.badge.img+1
I received this message: MinimumRequired cannot be greater than number of grouped tabs that are either selected or non-locked on specified Document. GroupLabel: Checkbox Group fb44bfe7-e507-448e-81c1-867fd9eaca12.
I understand what the problem is, but cannot find an instance of it in my document. Can I use the reference number (fb44bfe7-e507-448e-81c1-867fd9eaca12) to locate this issue in my document? If so, how can I do that?
Hello ​@DR Properties,
To recap, you are experiencing an error "MinimumRequired cannot be greater than number of grouped tabs that are either selected or non-locked on specified Document. GroupLabel: Checkbox Group fb44bfe7-e507-448e-81c1-867fd9eaca12". I apologize for any inconvenience caused. Please know that I am fully committed to helping you resolve this issue.
Alexandre suggested locating the checkbox field with the Group Label name  fb44bfe7-e507-448e-81c1-867fd9eaca12 to resolve it, and you would like to know how to search for it.
To share, that error message is talking about a Checkbox Group. So, the template has a group of checkboxes with a "minimum required" value (must select at least X), and that minimum value is higher than the total number of selectable checkboxes in that group. To locate it, Open the Template, select the checkbox fields on the template, the right panel displays the Group Label name. Look for the checkbox with Group Label: fb44bfe7-e507-448e-81c1-867fd9eaca12. Adjust the grouped tabs as needed.
Article: Checkbox Group Properties: Tooltip, Labels, and Values
I hope this is helpful to you. If you consider the response above useful, please click “Select as Best” to mark it as the “Best Answer ✅.” This will assist other users with similar questions in finding it more easily.
Let us know if you need further assistance with this. Thank you!
Alexandre.Augusto
Forum|alt.badge.img+18
Hello, ​@DR Properties
This fb44bfe7-e507-448e-81c1-867fd9eaca12 seems to be the Group Label name so you need to find which one is that in your document then fix the issue.
I hope that helps, if so, I’d appreciate your Like.
Best,
Alexandre
  • Author
  • Newcomer
  • April 28, 2025
Thank you Alexandre. I’d like to know how I can find that group label name--is there a way to search group labels to find this?
Forum|alt.badge.img+15
I trust all is well. I want to confirm if you were able to solve your issue by utilizing the suggested solution or if the information provided was useful. If so, please mark it as the "Best Answer ✅" by clicking “Select as Best” to make it easier for other users to find. Please let us know if you need further assistance. Thank you!
