i was sent a doc to sign ,I signned it now the link expired is there any way to pull that doc back up again please anyone that can help me get my doc pulled up HELP HELP!!!!!!
Page 1 / 1
If you did not have an account when the document was signed you can request that the original sender send you a new link.
There used to be a link in the ‘expired’ message for you to request a new link, not sure if that is still true.
If you did have an account before the document was signed, the document would be saved to your account. NOTE: opening an account AFTER the document was signed will not make the document appear. Accounts are not retroactive.
good luck
mr1
Reply
Sign up
You can login or register as either a Docusign customer or developer. If you don’t already have a Docusign customer or developer account, you can create one for free when registering.
Customer Login/Registration Developer Login/RegistrationDocusign Community
Customer Login/Registration Developer Login/RegistrationEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
