Pulling Checkbox tab group value from Power Automate
I am trying to pull the values of check boxes when checked using the built-in Power Automate connectors. I can see the name of each checkbox but I can’t tell whether or not the box is checked.
"tabLabel": "",
"documentId": "",
"recipientId": "",
"tabId": "",
"tabType": "checkboxTabs",
"prefill": false
JacobusNNew VoiceAuthor
I ended up changing from checkboxes to multiple groupings of radio buttons.
​@JacobusN , how did you capture the radio button values in power automate?
In this example I have a single signer role. You would use a function and build the expressions like
triggerBody()?['data/envelopeSummary/recipients/signers']?[0]?['tabs']?['Gender']
In this example my Radio Data Label is ‘Gender’ and it will return the value of the selection radio button.
Check this Support doc for additional information.
https://support.docusign.com/s/document-item?language=en_US&bundleId=gqy1619537336307&topicId=ayq1621896734683.html&_LANG=enus#:~:text=on%20an%20envelope-,Extract%20custom%20field%20and%20tab%20contents%20using%20Microsoft%27s%20Workflow%20language,-To%20access%20envelope
