21 CFR Part 11 signature placement - space required and alignment
The 21 CFR Part 11 eSignature requires more space on a document to prevent text overlap with other document text and multiple signatures. Are there any specifications on the amount of space required (height and width) and how to align the placement of 21 CFR Part 11 signatures when sending an envelope?
Hello @Lisa,
I apologize for the inconvenience that this might cause you, I know the importance of having the correct information displayed as needed in the envelope; I understand that you want to know the space required and the potential alignment for the Part 11 signatures.
We do not have a specific size for the signatures, because it can change depending on the information that is entered by the signer, you can use the Preview function to see what the general size of the signed field will be.
However, for the Part 11 accounts we offer two types of signatures, the Tall and wide signature options.
The tall signature is the default option, but if it doesn't fit on your documents, you can switch to the wide option. Administrators can configure the signature formatting option through an account-level setting, more information at Tall vs Wide Signatures on Part 11 Envelopes and Configure Tall or Wide Signatures for Part 11 Documents
Note: Some advanced features and options are supported only in specific DocuSign plans. Your account plan might not support some options discussed in this help topic. Contact your account administrator for more information about which options are available for your account. Or, visit our Plans and Pricing web page for more details on the features included with your plan. Compare eSignature plans & pricing.
Hello @Lisa,
Hi @Lisa,
