How does Docusign Maestro help increase efficiency?
  • May 29, 2024
  • 2 replies
  • 113 views
Forum|alt.badge.img
Limited integration hinders data exchange with systems of record and often requires time-consuming and expensive custom engineering work. How does Docusign Workflow Builder (formerly Maestro) help with this issue?
Docusign Maestro helps you minimize costly standalone integration projects by seamlessly extending workflow capabilities across your tech stack. Maestro enables you to easily build and deploy customized workflows that provide the necessary integrations to automate your agreement processes without writing any code.
Thanks for posting your question on the Docusign Community!
Forum|alt.badge.img
Sumit.Parikh
Forum|alt.badge.img+1
  • Docusign Employee
  • July 30, 2024
Docusign Maestro along with Docusign App Center enables customers to build end to end agreement process across your tech stack. You can visit Docusign App center to lean about list of integrations available - https://apps.docusign.com/app-center
