Conversation Starter
September 8, 2025
Is there a way to see the history on when reminders have been sent out per envelope
Ma.CubioAnswer
Hello ​@Teich
To see Reminder events in your Docusign envelope history, your account administrator must contact Docusign Support to enable this feature called "Reminder events in History", as it is a backend setting. Once enabled, you can view reminder history by going to your Agreements page, finding the specific envelope, and clicking More > History to view the detailed event log.
What you might see in the history:
  • When a document reminder was scheduled, changed, or deleted.
  • When a document reminder was processed or sent.
Important Considerations:
  • Account-Level Feature:
    This setting is not available to all users; an administrator is required to configure the account level.
  • Different Systems:
    If you use DocuSign CLM, the process and available history filters are similar but may have slightly different navigation options.
  • Resend Feature:
    You can always send a manual reminder to a signer using the resend envelope feature, which creates a manual reminder event in the history.
If you found the response a useful solution to your question, please “like” and mark it as the best answer by clicking “Select as Best” to make it easier for other users to find. Thank you!
Hello ​@Teich
  • Resend Feature:
Hello ​@Teich
TeichConversation StarterAuthor
September 25, 2025
Thank you for your response.  I needed to contact Docusign Support to enable this feature.
Diana Teich
