Active Voice
April 14, 2025
“You do not have access to send for signature” when using XML Merge in CLM as DS Sender
I’m working in DocuSign CLM and facing an issue during the “Review and Send for Signature” step.
Here’s the flow of my CLM workflow:
1. I use an XML Merge Document step to generate a Cover Letter, and store it in a variable (Cover_Letter_Generated).
2. This variable is then passed to the Review and Send for Signature step.
3. The person sending the document is a Legal Reviewer, who has a DocuSign Sender permission profile (not Admin).
Problem:
• When the Cover Letter is included via the XML Merge step, I get the error:
“You do not have access to send for signature.”
• However, if the Cover Letter step is removed, the same Legal Reviewer is able to send the document for signature successfully.
• The issue goes away completely if the sender has DocuSign Admin permissions, even with the Cover Letter included.
Expected Behavior:
I want to keep the sender as the Legal Reviewer (DS Sender) and still be able to include the Cover Letter generated by the XML Merge step.
What I’ve Tried:
• Checked workflow structure — the Cover Letter is stored in a variable and passed correctly.
• Verified that without the XML Merge step, sending works as expected.
• I can see the “Sender Email” option, but want to keep the sender as the Legal Reviewer.
Ask:
• Is this expected behavior that merged documents require Admin permissions to send?
• Is there any way to allow a DS Sender (Legal Reviewer) to send documents that were generated via XML Merge?
Vinicius.Rodrigues
Hi ​@Aishwarya Konki !
Did you check the security folder/file permissions? It’s mandatory that this CLM User has access to the Cover Letter, even as “read only”.
May this explain why a CLM Admin can execute this WF, since CLM Admin (for standard settings) has access to all CLM folders/files.
Active Voice
June 11, 2025
Hi ​@Vinicius.Rodrigues,
I have verified that the CLM user has access to the Cover Letter folder. Could there be any other reason?
Aishwarya
Vinicius.Rodrigues
Aishwarya
The other possibility is the permission profile setting on CLM and eSign. Essentially, on CLM, the users must have a CLM User profile (or higher), and on the eSignature, must have a DS Sender profile (or higher).
Active Voice
June 11, 2025
Thanks for the response ​@Vinicius.Rodrigues  - The user is a CLM User and DS Sender but still there is an issue
Vinicius.Rodrigues
Hi ​@Aishwarya Konki!
I still think there is something related to user permissions, since admins can do it without issues. Something related to folder/file security. Unfortunately, I’m not part of Docusign Customer Support, so I can’t check your account logs. In this case, I would recommend that you submit a ticket to them, and they’ll be able to support you deeper than I.
