Changing validation of text fields, losing the connection with webform fields
I created an extensive Webform for my internal team, but some of the text fields need to be changed to validate as Number and Date. When I tried to update them, I lost the connection to the webform fields and couldn't search them. Is there a way to fix this, or do I need to recreate everything?
Thank you!
Priscilla
Hi @priscillacouto,
We are glad to have you here and can't wait to help share as much knowledge as possible. I am sorry to hear that you haven’t been able to update your Web Form’s field validation settings, but I will assist you in solving the issue. If the field in question is linked to an eSignature field, try updating the field’s validation in your template, and then generate a new Web Form based on it. You can find detailed steps on how to edit your template, here:
To edit a template
Feel free to let us know if you need further assistance with this.Thank you for using Docusign, we hope you have a wonderful rest of your day!
Hi @priscillacouto,
To edit a template
​Hi @priscillacouto,
