can't get two signatures (same recipient) on same document
Long time user (12 yrs?), extremely frustrated with recent DS *upgrades.* I can no longer ask one recipient to sign/initial in multiple locations in the same document. The wizard automatically deletes the first/previous signature/initial if I add a second location for signature/initial request. I have tried closing/reopening the DS program, switching browsers, switching users in between, etc. Nothing is working and I have an urgent deadline.
Speaking or chatting with a human is no longer possible and the bot cannot provide adequate instruction. This is terrible customer service. DS rates have increased, yet the quality and availability of service has deceased. Shame on you DS.
I guess it’s finally time to switch to a more reliable digital signature provider.
I have the same problem. Someone please help!
Digital Leader
January 29, 2026
can you try to place signature blocks without using the wizard? Or are there setting you can change/override for the wizard?
I don’t use any auto-place/wizard/etc and I was able to place multiple signatures on different pages in the same document with no problem.
good luck
mr1
MR1
Sorry to hear your experience ​@jenlloyd  and ​@Ева Евтимова - I am sure there is a better solutiont hat can be worked upon your templates. How are you addign the signature tags on the document? Are you adding them and renaming them as well? while renaming are you changing the api name so the same by any chance?
If at all, I recommend to with work with support or share your template so that a solution can be recommended.
Hello ​@jenlloyd,
If you found my response to be a useful solution to your question, could you please click the like and "Best Answer ✅" button at the bottom of the post? It helps other community members who might have similar questions.
