Extracting Docusign Data > SharePoint using Power Automate?
I have (What i think is) a really simple request
  1. I have a Docusign Template I want to register new suppliers.
  2. When an envelope status changes to completed, I want to be able to extract the data from the docusign document such as ‘Entity name’, ‘GST Status’, ‘ABN Number’ etc
  3. Once I have this data, populate a SharePoint List with the respective info
Using the Docusign Power Automate actions, I have tried almost every action, and a combination of Tabs, Custom Fields etc.
Nothing seems to work!
Can someone please advise what actions / methods I need to use for this?
Hello @Workforcery ,
If you're already using the trigger action "when an envelope status changes" and its catching envelope-completed events, it will already contain all tabs and envelope custom field data inside it, so you don't need to use any other actions: Expanding Power Automate Series: Common post-signing tasks
