docusign connection with power bi
Good afternoon,
I would like to know if it is possible to connect the Docusign API to Power BI.
There would be some documentation that explains how to connect Docusign with Power BI.
There's no direct connector with Power BI, so you might need to use Docusign API or use a 3rd party connector like CDATA, Automate.io, Tray.io. In case of using Docusign API, you can find all the documentation about connecting and implementing Docusign API on the Developer Center (https://developers.docusign.com/). You might be able to pull the data by calling Docusign API from Power BI.
