Assistance Required for DocuSign Flow Error – "ANCHOR_TAB_STRING_NOT_FOUND"
I have created a Power Automate flow for DocuSign, and it is working fine when the KYS DOCX form is attached from SharePoint — the approver is able to sign without any issues.
However, I'm encountering a problem when I try to attach additional PDF files along with the KYS form (for review purposes) for the same approver. In this case, I'm getting the following error: "ANCHOR_TAB_STRING_NOT_FOUND."
Could you please help me resolve this issue?
Hello ​@Sai Pasupuleti,
Thank you for reaching out to the DocuSign Community! We appreciate your engagement and are committed to fostering a supportive environment for knowledge sharing.
We're sorry to hear about the error "ANCHOR_TAB_STRING_NOT_FOUND" within your flow. The issue often arises when the document needs to be properly converted to Base64 format 👉 Base64-encoding document content
If the issue persists, we recommend opening a support case so a specialist from our Microsoft team can investigate and provide tailored guidance. This may involve a closer look at your workflow and potentially require a copy of the documents and screensharing if needed.
How can I request a phone call from Docusign Support?
Le us know if you have questions or anything comes up. Here, if you need us!
Helpful? Mark it as "Best Answer" to help others too!
June 23, 2025
​@Sai Pasupuleti
In Power Automate, when using the DocuSign connector, make sure each tab (e.g., signature tab) is tied to the correct documentId
Hi there ​@Sai Pasupuleti,
How are you? I'm just checking in to see if you still need any help, and we'll gladly help you with any questions you may have. Have a great day!
