Active Voice
May 5, 2025
Parked
Conditional fields show on if a number is greater than or less than or text LIKE
Categories:eSignature
Conditional fields currently only allows display of fields if another field explicitly equals a string value. This should be expanded in a similar way to the Rule implementation, allowing users to select operators based on the field type, eg: >=, >, <=, <, =, != if a number type field; =, !=, LIKE if a string type field.
Thanks for sharing this idea with us, ​@Blueline. We’ve reviewed it and appreciate the thought behind it.
At this time, we’re not planning to pursue this request, so we’ve marked it as parked.
While it’s not on our current roadmap, ideas like yours help inform future direction if priorities change.
Thanks again for contributing your input.
Idea Submitted→Parked
