Scott.Nieman
Troubleshooter
Troubleshooter
February 26, 2025
Existing Functionality
Add OR operand capability to conditional rules on templates avoid duplicative tabs, and is not null for disabling other tabs
Categories:eSignature
Conditional rules template tabs is VERY limited, only allowing ONE filter condition.   This limitation requires the creation of duplicative tabs to enable visibility, etc.
Documentation for creation conditional rules in nearly non-existent and Support has guided me here (again).
The worst-case scenario is the W-9 which can be retrieved from the DocuSign Template Library.  This template does not meet the IRS Rule 1 for this form, failing to allow the EIN to be entered for individuals and sole proprietors.
In addition, there are duplicative tabs for EIN1, EIN2..EIN9, one set for each of the various business entity options.  Ideally the filter option would be a multi-select control, which in the background would implement the logical OR operator “|”, for example, if (Option == IND) | (Option == C-Corp) | (Option == S-Corp) etc, … then make the EIN tabs visible for data entry.
Another valuable feature would be to test for data entry, where if a tab.value is not null, then disable other tabs.  For example, if the EIN is being filled out, then the SSN tabs are disable.
Hi there, thanks so much for your idea, ​@Scott.Nieman. After reviewing your request, we found that this can actually be accomplished today using existing DocuSign functionality.
To achieve the type of multi‑condition logic you’re looking for, you’ll want to create your templates using DocuSign Document Generation (DocGen). DocGen supports AND/OR conditional rules within a single logic block, which allows you to show or hide content based on multiple values something the standard eSignature template tabs don’t support.
You can get more details on that here: Add Conditional Rules To Show or Hide Content
Idea Submitted→Existing Functionality
