Existing Functionality
Add help documentation to specify a Box location in an Agreement Rule action
Categories:eSignature
When adding an agreement action of archive to a rule, there isn’t an example for Box in the documentation. This is for the Customize folder path. There is an example for Google Drive. Request that this be added to the documentation.
Hello ​@msmith, after careful review, we’ve confirmed that this request can already be accomplished using existing features within .
We truly appreciate the thought and effort behind. your suggestion. While there isn’t explicit documentation available yet outlining the exact configuration steps, we’re hopeful that more detailed guidance will be published in the future.
To format the folder path for Box, the structure for routing documents to Box subfolders uses the exact same forward-slash (/) formatting as Google Drive. You simply type the folder names followed by a slash at the beginning of the "Customize file and folder name/path" field before adding your dynamic tags or file name.
Example: Client Agreements/2026/+[Recipient Name] - +[Document Name]
In this example, the completed document will be saved into the "2026" subfolder, which lives inside the parent "Client Agreements" folder in your connected Box account.
The Crucial Difference for Box (Case-Sensitivity): While the structural formatting is the same as Google Drive, Box has one very strict limitation: Box file and folder paths are strictly case-sensitive. If your actual folder in Box is named client agreements (lowercase), but you type Client Agreements/ (capitalized) into your DocuSign rule, the integration will fail. You will likely receive an error stating that an item with the same name already exists with a different capitalization. You must ensure that the path you type in Agreement Actions perfectly matches the uppercase and lowercase letters of your existing Box directories.
Idea Submitted→Existing Functionality
