Troubleshooter
September 6, 2024
In power automate I set tabs to optional but appear required when I send the document.
This happens with every tab when I set them to true
Hengfeng Ge
Hero
Hero
September 6, 2024
could you download the API logs for the sender. please reference this document:
https://support.docusign.com/s/document-item?language=en_US&rsc_301&bundleId=jux1643235969954&topicId=poz1578456669909.html&_LANG=enus
and show the json of the tab in request and response.
FreeLink/甫连信息
🏆 2024 APAC Reseller Growth Partner of the Year
🔧 The first in APAC to pass the DocuSign eSignature Technical Consultant certification.
🚀 Expertise in DocuSign integrations with on-premises systems for leading enterprises across various industries.
Feel free to reach out for collaboration opportunities.
kokosTroubleshooterAuthor
Troubleshooter
September 9, 2024
I’m not sure what exactly you mean by in request and response but this is from the api logs
 "tabs": [
      "anchorString": "\\PaymentDate1\\",
      "optional": true,
      "tabLabel": "PaymentDate1"
      "anchorString": "\\PaymentDate2\\",
      "optional": true,
      "tabLabel": "PaymentDate2"
Hengfeng Ge
Hero
Hero
September 9, 2024
the anchorString seems different from your screenshut. there should be full json or your request and response in the api log. hope can provide it.
FreeLink/甫连信息
Troubleshooter
September 10, 2024
The tabs are different becaus I was changing them to see if there is any diferrence. The issue remains the same. The file with the logs has plenty of files. Which one should I use? I found a workaround to hardcode the required field to the flow through a plugin, but I’m afraid this can be dangerous in cases like when the platform is updated…. In the example I provide below I didn’t apply the workaround so it is clear.
Anyway one of them contains these.
TraceToken: 045061bc-a37d-448b-b069-1f3a36dc723b
Timestamp: 2024-09-09T13:55:58.4159638Z
x-ms-tracking-id: 1cee10f2-7b10-417f-9c3b-78ccd4571b7c
x-ms-client-tracking-id: 08584757167763147531987323448CU42
x-ms-action-tracking-id: ffd5530e-aac0-41eb-b475-cafba79972c6
  "tabs": [
      "optional": true,
      "optional": true,
      "anchorString": "\\stuffName\\",
      "optional": true,
      "tabLabel": "stuffName",
      "value": "Nikolaos"
      "anchorString": "\\studentName\\",
      "tabLabel": "studentName",
      "value": "Nikolaos Kokolantonakis"
      "anchorString": "\\studentNumber\\",
      "tabLabel": "studentNumber",
      "value": "0620116"
      "anchorString": "\\stuffAmountWords\\",
      "tabLabel": "stuffAmountWords"
      "anchorString": "\\PaymentDate3\\",
      "tabLabel": "PaymentDate3"
      "anchorString": "\\PaymentDate4\\",
      "tabLabel": "PaymentDate4"
      "anchorString": "\\PaymentDate5\\",
      "tabLabel": "PaymentDate5"
      "anchorString": "\\PaymentDate6\\",
      "tabLabel": "PaymentDate6"
      "anchorString": "\\PaymentDate7\\",
      "tabLabel": "PaymentDate7"
      "anchorString": "\\PaymentDate8\\",
      "tabLabel": "PaymentDate8"
      "anchorString": "\\PaymentDate9\\",
      "tabLabel": "PaymentDate9"
      "anchorString": "\\PaymentDate10\\",
      "tabLabel": "PaymentDate10"
      "anchorString": "\\PaymentDate11\\",
      "tabLabel": "PaymentDate11"
      "anchorString": "\\PaymentDate12\\",
      "tabLabel": "PaymentDate12"
      "anchorString": "\\paymentAmount1\\",
      "tabLabel": "paymentAmount1"
      "anchorString": "\\paymentAmount2\\",
      "tabLabel": "paymentAmount2"
      "anchorString": "\\paymentAmount3\\",
      "tabLabel": "paymentAmount3"
      "anchorString": "\\paymentAmount4\\",
      "tabLabel": "paymentAmount4"
      "anchorString": "\\paymentAmount5\\",
      "tabLabel": "paymentAmount5"
      "anchorString": "\\paymentAmount6\\",
      "tabLabel": "paymentAmount6"
      "anchorString": "\\paymentAmount7\\",
      "tabLabel": "paymentAmount7"
      "anchorString": "\\paymentAmount8\\",
      "tabLabel": "paymentAmount8"
      "anchorString": "\\paymentAmount9\\",
      "tabLabel": "paymentAmount9"
      "anchorString": "\\paymentAmount10\\",
      "tabLabel": "paymentAmount10"
      "anchorString": "\\paymentAmount11\\",
      "tabLabel": "paymentAmount11"
      "anchorString": "\\paymentAmount12\\",
      "tabLabel": "paymentAmount12"
      "anchorString": "\\stuffAmount\\",
      "tabLabel": "stuffAmount"
      "anchorString": "\\paymentText\\",
      "tabLabel": "paymentText"
  "textTabs": [
      "optional": true,
      "optional": true,
      "optional": true,
      "value": "Nikolaos"
      "value": "0620116"
201 Created
Content-Type: application/json; charset=utf-8
Content-Length: 23774
X-DocuSign-TraceToken: 045061bc-a37d-448b-b069-1f3a36dc723b
{"textTabs":[{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","required":"false","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"recipientId":"50155904","width":"0","height":"0","errorDetails":{"errorCode":"DOCUMENT_DOES_NOT_EXIST","message":"The document specified was not found.  DocumentId is not found in envelope."},"tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate1","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"421","width":"0","height":"0","anchorString":"\\PaymentDate1\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"ccb8d0fd-6856-44b0-b6c7-614df36c5feb","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate2","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"432","width":"0","height":"0","anchorString":"\\PaymentDate2\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"2e7296f6-ad03-4f1f-9266-098280e11e3f","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"Nikolaos","required":"true","locked":"true","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"stuffName","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"225","yPosition":"179","width":"0","height":"0","anchorString":"\\stuffName\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"9160264e-2313-4309-8f92-a301a5b5570a","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"Nikolaos Kokolantonakis","required":"true","locked":"true","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"studentName","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"105","yPosition":"205","width":"0","height":"0","anchorString":"\\studentName\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"ed11d920-7adc-4e7b-8fd5-50123e0f3f67","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"0620116","required":"true","locked":"true","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"studentNumber","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"435","yPosition":"231","width":"0","height":"0","anchorString":"\\studentNumber\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"f7f80805-24a9-410b-b0cb-5f5491eed096","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"stuffAmountWords","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"116","yPosition":"322","width":"0","height":"0","anchorString":"\\stuffAmountWords\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"b99677d4-ee08-4d49-aa1e-2821662d9f7d","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate3","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"442","width":"0","height":"0","anchorString":"\\PaymentDate3\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"cfc7958b-465d-47d2-9110-28f91cec235f","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate4","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"452","width":"0","height":"0","anchorString":"\\PaymentDate4\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"0afdbef0-707e-4f4b-89f5-5ff9ce924068","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate5","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"463","width":"0","height":"0","anchorString":"\\PaymentDate5\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"6e8a8ac9-829d-4be4-9105-6ca71d966b8d","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate6","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"473","width":"0","height":"0","anchorString":"\\PaymentDate6\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"e6d15d41-6010-4950-8471-0d1ff186f42d","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate7","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"483","width":"0","height":"0","anchorString":"\\PaymentDate7\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"b7233dc2-5d8e-4866-853f-fdff5e06d762","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate8","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"493","width":"0","height":"0","anchorString":"\\PaymentDate8\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"c411ff10-23ed-4b29-ab1e-f890aa0628b1","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate9","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"504","width":"0","height":"0","anchorString":"\\PaymentDate9\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"366c79e3-33f5-4a2a-bc27-ed83fc771481","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate10","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"514","width":"0","height":"0","anchorString":"\\PaymentDate10\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"47358c3f-c2d3-4130-ae5e-b0dae54f2aa2","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate11","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"525","width":"0","height":"0","anchorString":"\\PaymentDate11\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"ae6bacd5-1441-4d42-9308-8674d7cbeea9","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"PaymentDate12","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"535","width":"0","height":"0","anchorString":"\\PaymentDate12\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"198bea27-efb3-4343-b7b8-9c2f539c1215","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount1","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"146","yPosition":"421","width":"0","height":"0","anchorString":"\\paymentAmount1\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"970fce3a-b9f6-474a-bf0d-095c3f1082ff","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount2","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"146","yPosition":"432","width":"0","height":"0","anchorString":"\\paymentAmount2\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"7cd778f7-44ea-4344-b23b-8573ef7212f6","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount3","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"146","yPosition":"442","width":"0","height":"0","anchorString":"\\paymentAmount3\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"b97e3226-91ae-498d-96bf-177a470bfe52","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount4","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"146","yPosition":"452","width":"0","height":"0","anchorString":"\\paymentAmount4\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"1d66ee2c-3494-4b65-b595-0e5e03d9b040","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount5","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"146","yPosition":"463","width":"0","height":"0","anchorString":"\\paymentAmount5\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"547b7606-f27e-4e28-93c1-b3a88b854423","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount6","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"146","yPosition":"473","width":"0","height":"0","anchorString":"\\paymentAmount6\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"a26278a9-091c-4f96-ad15-a044b1b7baaf","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount7","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"146","yPosition":"483","width":"0","height":"0","anchorString":"\\paymentAmount7\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"50817318-783b-4fab-9578-8d3cee8ebf16","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount8","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"146","yPosition":"493","width":"0","height":"0","anchorString":"\\paymentAmount8\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"a3af0678-5cc6-43f5-8946-9c971de88889","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount9","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"146","yPosition":"504","width":"0","height":"0","anchorString":"\\paymentAmount9\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"4317ba28-9605-4b22-8fde-1b6c174d4791","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount10","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"152","yPosition":"514","width":"0","height":"0","anchorString":"\\paymentAmount10\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"0f0515ed-aee1-4d83-9909-97496d6b75d5","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount11","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"152","yPosition":"525","width":"0","height":"0","anchorString":"\\paymentAmount11\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"a7a51bdc-6f07-4753-a093-f2a6b4e6f13a","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentAmount12","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"152","yPosition":"535","width":"0","height":"0","anchorString":"\\paymentAmount12\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"87a7a5aa-e10e-4794-920a-390665dbf3ea","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"stuffAmount","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"180","yPosition":"309","width":"0","height":"0","anchorString":"\\stuffAmount\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"a009ef8d-5101-4784-a4d3-14815b66eaeb","tabType":"text"},{"isPaymentAmount":"false","shared":"false","requireInitialOnSharedChange":"false","requireAll":"false","value":"","required":"true","locked":"false","concealValueOnDocument":"false","disableAutoSize":"false","maxLength":"0","tabLabel":"paymentText","font":"arial","bold":"false","italic":"false","underline":"false","fontColor":"black","fontSize":"size7","localePolicy":{},"documentId":"50152207","recipientId":"50155904","pageNumber":"1","xPosition":"73","yPosition":"566","width":"0","height":"0","anchorString":"\\paymentText\\","anchorXOffset":"0","anchorYOffset":"0","anchorCaseSensitive":"false","anchorMatchWholeWord":"true","anchorHorizontalAlignment":"left","anchorTabProcessorVersion":"v1_3","tabId":"81b431c1-0e79-4f19-be4f-257d3cc48537","tabType":"text"}]}
Troubleshooter
September 11, 2024
Request-Id: |58d42f521c6d07d5cccdd9405978c573.7eb2c5fef9e800c4.
traceparent: 00-58d42f521c6d07d5cccdd9405978c573-7eb2c5fef9e800c4-00
X-Forwarded-For: 20.54.57.0, 20.86.93.35
X-SecurityProtocol-Version: TLSv1.2
X-SecurityProtocol-CipherSuite: ECDHE-RSA-AES256-GCM-SHA384
  "tabs": [
      "optional": true,
      "optional": true,
      "optional": true,
      "value": "Nikolaos"
      "value": "0620116"
  "textTabs": [
      "optional": true,
      "optional": true,
      "optional": true,
      "value": "Nikolaos"
      "value": "0620116"
201 Created
Troubleshooter
September 11, 2024
