Current Routing Order Problems
Hi, I used the SDK for Java (Version 6.0.0) and i tried to use the function for Routing Order, but doesn´t works.
My Code
IntStream.range(0, userSigners.size()).forEach(i -> {
Signer signer = new Signer();
signer.setEmail(userSigners.get(i).getEmail());
signer.setName(userSigners.get(i).getName());
signer.recipientId(String.valueOf(i+1));
signer.setRoutingOrder(String.valueOf(i));
signer.setTabs(tabs);
signers.add(signer);
Recipients recipients = new Recipients();
recipients.setSigners(signers);
recipients.setCurrentRoutingOrder("true");
envelope.setRecipients(recipients);
This is correct?
