Using conditional recipients with document templates
Hi! I’m trying to build an envelope template tied to a document template that shows certain ‘Spouse’ fields if the recipient has a spouse. Here’s what I’ve done so far:
  • I created a document template with conditional fields to check for a spouse based on sender input. this shows or hides spouse text
  • I created an envelope template that I want to connect to my document template and here is where i get stuck:
    • the spouse is automatically added as a recipient because it is included in the document template. If I delete it, it obviously deletes the fields as well so they are no longer included in the document’s conditional text
    • I added a routing group for spouse, but then I cannot seem to add the signature within the document’s conditional rule
Is there any workaround without having to create 2 envelope templates?
Thank you!
Hello ​@IoanaC,
Thanks for reaching out here in the Docusign Community -- great to have you here
You've actually run into one of DocuSign's known limitations: conditional field rules control field visibility, but they can't conditionally include or exclude a recipient from the signing workflow. Those are two separate systems that don't connect the way you'd expect.
Signature tabs and field tabs must always be "owned" by a specific recipient. So when you remove the spouse recipient from the envelope template, their tabs go with them, even if those tabs were set up inside a conditional rule in the document template. This is why there's no clean way to make it work within a single template.
Unfortunately, two envelope templates are the recommended path here, one for "no spouse" and one for "has spouse." They can be nearly identical, except for the recipient routing, which keeps everything predictable and maintainable on the sender's end.
Hope that clears things up!
Best Regards,
If this cleared things up, you can mark it as "Best Answer" so others can find it, too.
Hello ​@IoanaC,
Best Regards,
IoanaCNew VoiceAuthor
Oh, understood! Many thanks for the help!
Hello ​@IoanaC,
We’re glad to hear that the information was helpful. If you found it valuable, we would greatly appreciate it if you could mark this as the “Best Answer”—this helps other community members easily find trusted solutions.
Please don’t hesitate to reach out if you need any further assistance. We’re always here to help!
Best Regards,
