Signature problem
I am trying to buy a house and my Docusign signature has change my middle initial from M to L.  Im trying to change it but I cant figure out how on the website.
Inki.KimAnswer
If you have a Docusign account, this should be under your profile > signatures.  It is also possible that this is the way the Sender sent it and you would have to reach out to them to correct it if you can’t.
Inki.KimDocusign EmployeeAnswer
Hello ​@Kerrigan,
I hope you are doing well. I want to confirm if you were able to solve your issue by utilizing the suggested solution or if the information provided was useful. If so, please mark it as the "Best Answer ✅" by clicking “Select as Best” to make it easier for other users to find. Otherwise, let me know and I will gladly help you address the situation as soon as possible.
