Conversation Starter
April 9, 2026
Regex pattern for a number that cannot be more than 10 digits but will still allow to enter less than 10
Looking to find out if anybody is using a regex patter for the numbers in a text box as a validation to only allow user enter max of 10 numbers but is still able to enter less than 10, without being forced to add zeros in front of it if the number is less than 10 digits. And is still able to complete the envelope.
Thank you,
Hi ​@Blanka Weber,
I appreciate your response.
I’m glad the information provided helped resolve your concern. Could you click the “Best Answer ✅” button below the post? That helps others in the Community find trusted answers faster.
If anything else comes up or you hit another roadblock, don’t hesitate to reach out here in the Community.
Hello ​@Blanka Weber,
You can use this regex to allow numbers only, up to 10 digits: ^\d{1,10}$  . This lets users enter fewer than 10 digits, blocks anything over 10, and doesn’t require leading zeros.
Please note that DocuSign Support isn’t responsible for creating or troubleshooting custom RegEx. Any examples shared are provided on a best‑effort basis and should be tested and used at your discretion.
I hope you find this helpful. If you believe this response effectively addresses your question, you can mark it as “Best Answer” to help other users with similar questions and to make it easier to find. Should you require any additional assistance, feel free to reach out. Thank you!
If this helped, like 👍and mark it as “Best Answer”.
Hi ​@Blanka Weber,
I hope you’re doing great. I would like to check whether the information provided helped resolve your concern.
Please let me know if you need any further assistance, and I’ll be glad to help.
Thanks for being part of the Docusign Community!
April 20, 2026
this worked, thank you for sharing this information. I greatly appreciate it.
Hi ​@Blanka Weber,
