Need help
I have a signed document and it came back to me as signed but with the words across it “IN PROGRESS” Its very time sensitive and I cannot find a live support person to talk to. What kind of business is this?
Does anyone know why this is happening and how to fix it fast?
Thank you
Sheri Davis
Robert Jackson
Rising Star
Rising Star
February 17, 2025
Did you send it out or was it sent to you?
You may only be part of the workflow the wording implies that other people have actions on the workflow after you have signed.
Helping the wider community work better with DocuSign - Contact robert@icit.co.uk for more information
Hello ​@Sherid,
If so, please mark it as the "Best Answer ✅" by clicking “Select as Best” to make it easier for other users to find.
Hello ​@Sherid
If you found the response to be a useful solution to your question, could you please click the "Best Answer ✅" button at the bottom of the post?
It helps other community members who might have similar questions. Thank you!
