Help with adding in my own signature to templates
Hi there,
I’d love any help on how to add in my initials and signature into new templates that I’m creating. I can only get it to add in the initial or signature prompt/field but it doesn’t show my esignature or e-initials. I’ve looked through Youtube videos and can’t seem to see how to do this. I’ve jumped into preview to see if when I add in my signature field that it pulls through correctly, but it isn't working…
Any help would be appreciated.
Thank you!
Paige
neethujkp
neethujkpAnswer
Frequent Contributor
July 9, 2024
Hi Paige,
I would suggest free form signing in that case.
If you are the first signer, then choose freeform signing for yourself (send without fields)
System will prompt you to Sign Now at the preparation stage itself.
If you believe my answer effectively solves your problem, please remember to mark it as the best answer and consider following me.
neethujkp
neethujkpFrequent ContributorAnswer
July 9, 2024
Hi Paige,
Hello @Paige J ,
