Help! How do I add an electronic signature to a DocuSign document for my Manager?
Hi - How do you add your manager’s electronic signature to a DocuSign document - if they are sent a Docusign document from an external entity?  I have received a few of these but havent been able to add their signature for them, is there a way to do this?  I havent used DocuSign before - just using the 30 day free trial to try and work this out! Thank you
Ma.CubioAnswer
Hello ​@Fleurbees,
To upload and sign a document in DocuSign, you need to:
  1. Upload the electronic document or pdf.
  2. Add signing fields.
  3. Drag and drop your signature, initial, dates, or other custom fields to fill in.
  4. Select "I'm the only signer".
  5. Sign the document electronically.
  6. Email your signed document or share it.
As an administrator, you can configure the format for signature adoption.
  1. From the Accounts view, select Signing Settings.
  2. In the Signature section, select the Signature Adoption Configuration link.
  3. Set the signature adoptions options described in the following topics.
  4. Select Save to save your changes.
Instructions above should be applied to the envelope recipient which is your manager.
Hello ​@Fleurbees,
Hello ​@Fleurbees,
