Dovument not using signature I created
I created a digital signature but the document that needs my signature does not use the signature I created.  How can I force the document that needs my signature to use the signature I created?
Hi ​@F Lance Pedriana,
Welcome to the Docusign Community — great to have you here. I understand that you are having trouble applying the configured signature to the document you are signing. I’m here to help!
If Docusign is defaulting to an older signature style despite your recent updates, you can manually override it during your active signing session by following these steps:
  • Open and click Review Document.
  • Click the Sign field to place the signature.
  • Click directly on your signature and select Change
  • Choose your new style from your saved options.
  • Click Adopt then Replace.
However, there are certain scenarios in which you can’t change your signature. You can find it here: Why Can't I Change My Signature?
Please let me know if it works!
Best Regards,
Click “👍” and Best Answer so other users can see it too!
I wanted to quickly check in and see if you had a chance to review my recent response to your post.
If the solution worked for you, please consider marking it as the "Best Answer ✅." This helps other community members with the same question find the solution easily.
Let me know if you need any further help!
Best Regards,
