Docusign Mobile-Friendly Problem
I have an adobe acrobat PDF that is being sent for signature. It is pre-filled so I’m selecting the “preserve PDF” or whatever the actual phrase is. When the recipient views the document in mobile-friendly mode, the layout of the document is all out of wack. How do we fix this? Thanks!
Alexandre.Augusto
Hello, ​@Chad
Using the option “Responsive Signing” in the envelopes makes easier to the users read documents using a mobile device, however for some .PDF forms that can cause the side effect mentioned by you.
Before sending an envelope with the mentioned .PDF form, go to the Advanced Options of the envelope then unselect Responsive Signing to disable it.
Verify if that solves the issue.
More details about Responsive Signing can be obtained here.
Best,
Alexandre
Alexandre.Augusto
Hello, ​@Chad
Best,
Alexandre
Hello ​@Chad,
