lvincent
Active Voice
Active Voice
November 26, 2024
Customizing the Sender and Body of the Verification Code SMS in DocuSign
Is it possible to customize the sender and the body of the verification code SMS sent by DocuSign? I am currently using RecipientSMSAuthentication for a signer to send this SMS.
Thank you in advance for your feedback !
Hello ​@lvincent,
Are you sending with the regular Docusign Web App or are you creating the envelopes using an API?
Hi ​@lvincent,
lvincent
Active Voice
lvincentActive VoiceAuthor
Active Voice
February 13, 2025
Bonjour@Christopher.Alpizar ,
Nous utilisons bien l’API. Avez-vous une solution pour personnaliser l'expéditeur et le corps du SMS de code de vérification envoyé par DocuSign lors d’une signature à distance ?
Merci pour votre retour,
Cordialement,
L. Vincent
Troubleshooter
February 19, 2025
Hello ,
Yes we are using Docusign API, sending SMS thanks to RecipientSMSAuthentification class.
According to your documentation “Docusign signing resource file guide”, we can customize it by changing the data ActivationSec_SMSAuthCodeMessage, but its not working.
Arthur
Troubleshooter
February 26, 2025
we are still working on this point, could someone help us please ?
Arthur
Troubleshooter
March 4, 2025
Hello , ​@Christopher.Alpizar ,
could you help us ?
