EduardoFromTheFuture
Is it possible to integrate Connect with WebForms?
We have a published webform - "id":"3527eec7-2c68-43f0-aca9-9eb51c4e7a16","accountId":"d09a0de1-8019-4bf8-a56c-46916ffdf531".
When users complete it, is it possible to have it trigger Connect to send a webhook request? I don't see anything related to WebForms in the list of possible triggers for Connect - maybe it is not supported or maybe it is under a different name?
Thank you!
Hi ​@EduardoFromTheFuture
Thanks for reaching out to the Docusign Community.
There is currently no Web Form event trigger in Connect. Envelopes are generated only for web form instances created from template-based web form configurations. If that is your case, you can track these envelopes in Connect and check whether they are complete. You can learn more about monitoring web forms instance status in the link below.
https://developers.docusign.com/docs/web-forms-api/plan-integration/track-instance-and-envelope-status/#web-form-instance-status
