DocuSign Connect not sending document field values via webhook
  • January 23, 2025
  • 1 reply
  • 175 views
I’m using DocuSign Connect to send a webhook to Zapier when a document is completed. When I review the output of the webhook sent to Zapier, I do not see the document field values.
My custom connect is set up using REST v2.1 data format, SIM delivery mode, and data included is the following:
  • Custom Fields
  • Documents
  • Attachments
  • Document Fields
  • Recipients
Has anyone else had this issue or know a way I can adjust my configuration so that the output includes the document field values?
Best answer by Adrian Dev
Hello IK1919 ,
Thank you for contacting Docusign Customer Support.
Please check "TABS" in your Docusign Connect data configuration to include the fields inside the documents.
Additiona information:
Additional Data That Connect Messages Can Include
Adrian | Docusign Developer Support
Digital Collaborator
January 26, 2025
Hello IK1919 ,
