Confirmation that Send With DocuSign in a Salesforce flow works
  • July 18, 2024
  • 1 reply
  • 271 views
Hi team,
I have a Custom button calling screen flow in Salesforce. The flow is setup to “Send with DocuSign” as per below:
I have quite extension Screen documentation for errors, and the flow completes successfully:
The envelope (related to the ID I’m using above) works when I execute it directly - however, when the flow completes, I don’t get any errors, it completes, but the Envelope is not sent.
If I edit the envelope template ID slightly, the flow fails - so I knwo the ID is correct… Similiarly, I know the correct object is being sent through…
Is it possible to get any feedback from the APEX action so I can tell if it worked or not. As you can see the flow is designed to create an object to hold all the responses from the docuemnt - but otherwise its pretty straight forward. I can use this object to track a status if one exists!
I’m having the same issue! I’ve been testing with myself as the recipient and I don’t see the envelope sending in Salesforce and I’m not receiving it via email.
Were you able to make this work @PaulAtIExtend ?
