Right and Role - Signatures
  • April 26, 2024
  • 2 replies
  • 153 views
Hello everyone.
I would like to setup a meaningful rights role concept.
I would like to have users who are “only” allowed to send simple signatures, but cannot make any other settings.
There should be 3 users who can also send qualified electronic signatures, while others cannot.
I would also like users to be able to send letters exclusively via API.
Can this be done with the setting?
Thanks - and have nice weekend
Best answer by Michael.Rave
@danny.schumann
Signature type are managed on an account level. Therefore, you would need to create a sub account for the three users that should be leveraging QES. This is common practice to meet this requirement.
In regard to sending exclusively via API, this is an uncommon request as the Docusign eSignature Web App is also build on top of the same APIs. Therefore, users will always be able to do things based on their permission profile, regardless of it being directly in the Docusign eSignature Web App or another integration. They will be able to log into their individual accounts and potentially send things from there. Unless you prevent them from logging into the Docusign eSignature Web App and only give them the option through your integration. In that case you may think of using a system sender for the integration and them not having individual accounts that can be used to log into Docusign eSignature Web App. If you assign them a “DS Viewer” permission profile, they cannot send envelopes at all, neither the Web App or through an API integration in their name.
Michael.Rave
@danny.schumann
Hello, thank you for your tip.
I've been reading through the support book for a while now,
I have the Business Pro Pack, in which I can't make all the settings as described, can I?
Sub-accounts are not possible here. I can't really change much about the user groups.
Is the Enterprise Pro really necessary for this?
Thanks again
