Deactivation of API connection between Docusign and SuccessFactor
  • October 11, 2024
  • 2 replies
  • 123 views
Hello All,
Could you please help me with the following question - how I can temporarily deactivate API connection between Docusign and SuccessFactor?
Thank you!
Serge Shelkoshvein
Best answer by Ivan.Dinkov
Hi @sshelkoshvein
Regarding if this could be done from SAP SF, you would need to reach out to their support.
From Docusign you can disable the integration user/s. If you have used your own integration key, you can delete your secret and private keys. This will prevent authentication
Ivan.Dinkov
Hi @sshelkoshvein
Ivan D
Hi @Ivan.Dinkov,
Thank you for your response, will do this!
