April 26, 2022
how to fix tiny initial and signature boxes?
Thank you for reaching out to the DocuSign Community.
That issue is due to the document having large dimensions, please view issue 3, Cause and Solution A from the following article to fix this: https://support.docusign.com/s/articles/Issues-Uploading-Documents-Common-Errors-Causes-and-Solutions?language=en_US&rsc_301
Please let us know if you require further assistance.
You can always create a case to have a Support agent work the case with you.
If you are not able to open the case on the same page, you should scroll down to More Support Options and select "I can't reset my password or don't have an account." you will have the option of filling out the form or calling Support.
April 26, 2022
Thanks – I appreciate the assistance
