Hello, @LPSkeen
You are welcome to the Docusign Community.
When creating your envelope, click in the Signing Order checkbox.
Add your user as the first recipient then the others as 2nd, 3rd, etc.
In the contract, add Sign Here for your user and the others in the respective locations.
Add any other field that you think is necessary.
Send the envelope.
You will be the first to receive an email to sign, click in the Review Document, sign it. Now the envelopes will go to the next recipient.
In case you are not seeing your Sign Here field, I suggest you to logout from your account. Open a new browser session, login again then sign your envelope.
I hope that helps,
Best,
Alexandre
