fixed approval/ corner sign flow
Can we set up a fixed approval/ corner sign flow so that nobody can change it?
Thanks!
Hello @m3l001 ,
I understand you are looking for a way to set an approval workflow that no one can change.
You can create a template with a predefined approval workflow, share it with your users and limit changes to that template from other users. Please note that the limitations would only affect recipients, email messages and branding, fields are not included.
For more information, please view the following article: Protect your shared templates
Hengfeng Ge
Hero
Hero
April 26, 2024
we are the partner of docusign:
https://partners.docusign.com/s/partner-profile/aNQ8Z000000wk2dWAA/freelink
have you integrate the docusign with your system. Our customer always integrate their workflow with docusign, after the workflow trigger send envelope automatically. so nobody can change it.
Hello @m3l001 ,
Hello @m3l001  ,
If you found my response to be a useful solution to your question, please mark it as the best answer by clicking “Select as Best” to make it easier for other users to find.
