DocuSign Frame numbers - are they randomly generated?
  • August 28, 2024
  • 5 replies
  • 3229 views
When using the DocuSign frame on documents, are the number below the signature randomly assigned?
For example, if I sign numerous documents - will the numbers below my name at the bottom of the frame always be the same? Or do they change from document to document?
Please see below (the identifying signature has been removed)
Best answer by JohnSantos
@CHToronto
The numbers displayed beneath your signature in the signing frame are not randomly generated. These numbers represent the DocuSign Signature ID (also referred to as the Signature GUID), which is associated with your DocuSign user profile and the email address used to sign.
If you sign using a different email address, a different Signature ID may be generated because it is tied to the signer’s identity, not to an individual document.
It’s important to distinguish the Signature ID from the certificate of completion and audit trail details. Information such as the envelope ID, document ID, timestamps, IP address, and signing events are unique to each document and each signing session. These values change from envelope to envelope to ensure every transaction is uniquely identified, secure, and fully traceable.
Pawan Gangwani
Hero
Hero
August 28, 2024
Hello @CHToronto
I am attaching the link here for the same question answered by the community expert.
Here is link for more info:   Signature Adoption and Format
Thanks!
August 28, 2024
@CHToronto
CHTorontoNew VoiceAuthor
Thank you, John!
Hi @CHToronto,
Thanks, Christopher! John answered my question right away and it was very helpful. Clare.
