Auto navigation settings
  • August 5, 2024
  • 2 replies
  • 383 views
Can anyone let me know how I can change the auto navigation settings for recipients. I would like to change it to stop at the top of every page rather than just shooting from signature box to signature box. From what I have read it’s possible but for the life of me I cannot find the settings to enable to me to make this change.
Many thanks.
Best answer by Christopher.Alpizar
Hi @JackieMc,
Digital Leader
August 5, 2024
@JackieMc
It looks like you want to set “Auto Navigate” to “Page Only” (Settings - Signing Settings)
The setting is explained about 3/4ths of the way down the page:
https://support.docusign.com/s/articles/How-do-I-auto-navigate-or-skip-past-optional-fields-such-as-check-boxes-or-radio-buttons?language=en_US
good luck
mr1
MR1
Hi @JackieMc,
