id veryfication problem
Hi There, I would like to add Id veryfication for the person who will be signing contract with me. But dont see any uption to add this requiements. In the settings I add option that veryfication is required, but when customising the contract options there is only posibility to send the code as a veryfication methode.
Pawan Gangwani
Hero
June 17, 2024
Hello @momorze
Welcome to the community! I hope you are doing great. Please view the following article for more information on how to set up the ID verification for recipient so here are some support articles:
1. eSignature ID verification set up
2. To add ID verification for a Recipient
And if you are looking for this option to show up:
then follow the instructions:
1. Go to the eSignature settings and navigate the “Security Settings”
2. Enable the second option in “ Recipient Authentication Settings”  refer the SS.
Keep me on Radar if you need further assistance and id this solution works for you, then mark it “Best”🌈
Thanks!
Pawan Gangwani
Hero
Hero
June 17, 2024
Hello @momorze
Thanks!
Hi @momorze
