Conversation Starter
March 5, 2024
We are integrating DocuSign with workday testing tenant, while we are testing on offer letter encountered following questions.
  1. I would like to ask if it is because we authenticated DocuSign developer account to our testing tenant with my credentials, it shows up my name on top(Highlighted)
  2. Is it because we are in our testing phase and using developer account it is giving  Demonstration document only on top of page in offer letter?
Hello @Kalyan Teja ,
  1. The reason that your name appears in this location on the document is that you are signed into DocuSign with your account.  This may be because the developer account is in your name or because you are logged into the developer account, or because when the integration was set up it was done with your email account address.
    It is possible to make this come from a more generic address, such as from administrator@woodbine.com but you would need an Enterprise Pro account, claim your domain (e.g. @woodbine.com) and set this up.
    2. Yes.  In a production account this message would not be displayed
March 6, 2024
I would like to further ask about the 1st question:
1.My name at the top will just be showing for the test build correct? In the final build(production) that won’t be present?
2.If nothing specific is required in the final build(production) were it currently shows my name that will be blank in the final build, correct?
Please advice.
Thanks in advance!
Hi Kalyan,
  1. There will be a name there from whoever was the sender of the document - as is the person logged into the DocuSign account and clicked send.  With that said, per my last post, if you have a generic email address e.g WoodbineAdmin@woodbine.com, it would say from WoodbineAdmin, or if you have an Enterprise Pro Account plan and claim your domain you can also genericize the ‘from’
    2. Per #1 here - No.  It still will have a ‘from’ but larger organizations tend to genericize it by claiming their domain
April 15, 2024
May I know how to change DocuSign Sandbox Administrator Email Address?
Thanks in advance!
Thank you for reaching back.
The email address would either need to be changed by the admin directly by going to:
  1. Click on profile image in the DocuSign account: Change Your Email Address
  2. Select "Manage Profile" from the dropdown menu.
  3. The My Profile site will open.
  4. Update your email address in the Email Address section.
  5. If required, log in to authenticate your account.
  6. Select "CONTINUE" and enter your new email address.
  7. Click on "SEND CODE".
  8. A confirmation email with a verification code will be sent to your new address.
Other wise, what can be done would be to open a new account with the correct email address and transfer any needed documents as mentioned in the following article: How can an administrator change a user's email address?
April 18, 2024
Thank you for your support!
My other question is:
Some of the hiring managers are not getting ‘Don’t Accept’ button under ‘eSign by DocuSign’.
May I know why is that?
That doesn’t look like the normal DocuSign interface, would that be Workday?
If it is Workday, I would recommend you reach out to them, as the integration is own by them and would be better suited to assist you.
May 28, 2024
I have configured DocuSign to our testing tenants during our workday implementation and it works alright.
Thankyou for your support.
May I please be advised on how is it going to be in the production tenant?
Will I have to use DocuSign enterprise account to authenticate with workday production tenant?
Please advise.
