May 1, 2023
When using the mobile application will be compatible with the FDA CFR part 11 regulation?
We are using the eSignature CFR part 11 module, if using the mobile application will be compatible with the FDA regulation it will be most helpful for the management that travels often.
We apologize for the inconvenience, but when using the mobile app with the following features:
Envelope level (using one of these features will prevent all signers on the envelope from signing via the mobile app):
  1. Supplemental Documents
  2. Sent from a 21 CFR Part 11 compliant account
  3. Pre-fill Document Fields
 Recipient level (if a recipient has been assigned one of these fields or roles, they will not be able to access the envelope from the mobile app):
  1. Standards Based Signatures
  2. eHanko
  3. Specify Recipients
  4. Allow to Edit
  5. Update Recipients
  6. Signs with Notary
Your signer will receive the following message "Complete this document in a browser. Completing this document is not supported in the mobile app. To complete, open this document in a browser.", and will have to access DocuSign through the mobile web browser or a computer.
The features listed above are not compatible with the mobile app.
More information at https://support.docusign.com/s/articles/DocuSign-Mobile-Action-Not-Supported-Error?language=en_US&rsc_301
  2. eHanko
  4. Allow to Edit
