Template Fonts Changing with Power Automate
  • October 11, 2024
  • 7 replies
  • 324 views
Hoping someone can help us here… we have a Power Automate flow that updates Prefill tabs on a template in DocuSign from a SharePoint list. All of the Prefill tab fields are set to Times New Roman Font, Black, Size 12. When the envelope is sent, it changes the font of the data in the tabs. I tried to set the font in the workflow but it didn’t work. Has anyone else experienced this?
Hello @SVDB-PowerAutomate,
Is this happening regardless of the font that is being used? Would it be possible for you to provide a screenshot of this issue?
Thank you for your response. All of our font is set to Times New Roman in the template, prefill tabs and in the workflow. You can see in the screenshot
In addition, it looks like 2 tabs are getting placed, often on top of or right next to one another. This is not visible in the mobile view but is available in the browser view. It is also visible to the recipients when signing but not once the envelope has been completed. Please see screenshot.
If the fonts are being change there is the possibility that a bug might be affecting the account, have you created a case with Docusign Support?
I do have a ticket open. Thank you!
Any thoughts on the prefill tabs and workflow?
The envelope, is it design to be completed in a mobile device or a desktop or laptop?
It should allow you to view on any device the user chooses.
Can you provide the case that you opened with Docusign Support? I think that this might be another potential bug.
